Programming a CDM1550-LS
erikjwheeler
Hi all,
Can someone point me in the right direction for how to program a CDM1550-LS?
  • I have version R06.12.05
  • I am not sure what version was originally used to program the frequencies
I have searched online, but have been unable to find consistent information. My questions are:
  • What kind of cable do I need?
  • Which version of Windows can I use?
  • If I need a different version of CPS, can I purchase it from Motorola, or is this radio too old?
Thanks for any suggestions you have.
n3obl
Ø
PA
That version is fine. Just need a programming cable off ebay.
Project25_MASTR
Millennial Graying OBT Guy
Texas
I've not had any luck trying to run the Professional series CPS on a 64 bit Windows machine. I've always had issues with how the CPS wants to handle the COM port. Windows XP and Windows 7 32 bit have worked flawlessly for me though.
erikjwheeler
Ok thank you both, that is helpful. I have tried it on a 64 bit Windows machine, but am getting errors, so I'll try an older version of Windows.
Project25_MASTR
Texas
What I used to do when I was running Windows 7 64 bit (professionally) was use XP mode to buffer the COM port and that worked fine.
chrismol1
P25 TruCking!
I have no problem programming my EX560XLS on my Win 7 64 bit with R6.12.05, the only thing is I use a USB to serial converter cable to a serial programming cable
R8000
Low Battery
I use Win7 64 bit Core I7 with Professional Series CPS just fine.
I use the Valley Industries USB programming cable. I installed the driver they provided and the CPS see's the USB cable com port fine.
I can vouch that 64 bit does work, but with so many variables with people's computers, maybe something unique to your setup is stopping it form working?
