I THINK I've got the right one. It uses a DOS type with mouse support. VHF or UHF. You'll need a slower/OLD operating system.
GX1508 PPS. You MIGHT be able to adapt a VPL-1 or CT-42 instead of finding an actual PPS and cable.
This is the Read Me -
5/14/91
PPS SOFTWARE OPERATING INSTRUCTIONS
1. STARTING THE PROGRAM
To run this programming package, you need the following hardware and software:
* an IBM PC, XT, AT or 100% compatible computer
* at least the minimum amount of free memory (RAM) shown in Table 1
* a 5.25-inch double-sided floppy disk drive
* MS-DOS version 3.0 or higher
---------------------------- CAUTION -----------------------------
It is important to back up this diskette before using it for programming purposes. Do not use the master diskette
to run the program. Keep the master diskette in a safe place. Installing DOS on it is not recommended. Master
diskettes should be kept in their original state in the event that copies become damaged. Refer to a DOS manual
for instructions on backing up a diskette.
To check the amount of free memory, insert the diskette into the disk drive and at the DOS prompt type:
MEMORY <ENTER> Compare the amount of free memory shown on the display with the
amount from Table 1 for the model you wish to program. In order to run this programming package, you must have at least the amount of
free memory (RAM) specified in Table 1.
Table 1 Minimum Free Memory (RAM) Requirements
HX240 ..................... 202 Kbytes
HX340 ..................... 116 Kbytes
HX440 ..................... 434 Kbytes
HX530 ...................... 97 Kbytes
GX1500 .................... 324 Kbytes
GX2000 .................... 124 Kbytes
GX3200 .................... 449 Kbytes
To start the program, at the DOS prompt type in "PPS" followed by
the numeral-portion only of the model number:
A: PPS(model number) <ENTER> (for floppy drive), or
C: PPS(model number) <ENTER> (for hard drive)
Example: To load the program for programming the GX1500 from the A:
drive, enter:
A: PPS1500 <ENTER>
The program will load and display the Menu Bar across the top of
the screen. A menu window in the center of the screen will display
the version number and ask if you are using a color or monochrome
display. Select the correct response with the <TAB> key and then
press the <ENTER> key or the space bar.
2. THE MENU BAR
All of the programming functions are grouped into submenus. To
access the submenus, press the <ALT> key; the first submenu will be selected and one letter of each of the other submenus will be
highlighted. The other submenus can be selected with the "UP ARROW" and "DOWN ARROW" cursor keys. Press <ENTER> to select the
highlighted submenu or press the key corresponding to the
highlighted letter to select any of the other submenus.
When a submenu is selected, a pull-down menu will appear with all
of the submenu items displayed. Again, the first item will be
highlighted and each of the other items will have a highlighted
letter. The other items in the submenu can be selected with the
the desired item or press the key that corresponds to the
highlighted letter to select any of the other items in the submenu.
Some of the items can be selected by pressing a function key (if
displayed).
Once a submenu is pulled down from the main menu bar, you can move between the submenus by using the "LEFT ARROW" and "RIGHT ARROW"cursor keys, displaying all of the submenu items. Pressing the
<ESC> returns to the main menu bar.
3. ENTERING DATA IN THE SUBMENU
Once a submenu item that requires data entry has been selected, a
data window will appear with the data fields in the top section of
the window, and a number of functions enclosed in brackets in the
lower portion of the window. Pressing <ENTER> will execute the
highlighted function. Use the <TAB> key to move between functions
or to return to the data fields. Entering data is done by direct
entry on the computer keyboard (in the case of frequencies) or by
selecting predetermined values using the indicated keys (+/- keys,
space bar, etc.) Move between the fields with the cursor keys ("UP
ARROW", "DOWN ARROW", "LEFT ARROW" and "RIGHT ARROW").
Do not press <ENTER> after inputting data; pressing <ENTER> will
execute the highlighted command in the lower portion of the window.
If an error occurs in data entry, an error window appears with a
message and a number of functions enclosed in brackets. Select the
appropriate function with the <TAB> key and press <ENTER>. When all
of the data has been correctly entered, select <OK> and press
<ENTER> to return to the Main Menu.
4. USING A MOUSE
If you have a mouse installed, all of the menu items can be
selected by pointing to the item with the mouse "cursor" and
clicking the left button. The only time you need to use the
keyboard is for entering channel data.
5. PRINTING THIS FILE
To obtain a hardcopy printout of these instructions, at the DOS
prompt enter:
COPY README PRN:
