Programming APX 8k Toggle Switches
MFG_rrt
CPS 17, trying to program my toggle switches (on/off, and A,B,C). Can you tell me why “Scan” and others are red and can’t be used?
glradio
OES Region 1 Area C
Are they set anywhere else? Check the menu options and side buttons.
KE4ZNR
Radio Guru
Probably because you have them as a soft key option in the menu layout. You can assign them as soft key menu option or toggle switch but not both.
Marshall KE4ZNR
Sent from my Pixel XL using Tapatalk
MFG_rrt
Marshall KE4ZNR
You were both correct. I had them in the soft button menu.
Thanks.
