BCD325P2/BCD996P2: Programming assistance
PD47JD
Connecticut
Recently had a 996P2 programmed by Scanner Master...but, that's another story yet to be dealt with. So, I am attempting (miserably) to acquaint myself with the operation of the 996P2. Somehow, through inadvertence, I did something: the radio now does a general band scan/search whenever a preprogrammed frequency is inactive. So, it will stop to receive on a programmed channel and then start a general band scan then stop when there is activity on another programmed channel and then start a general band scan, etc. Do not want a band scan function in between reception of programmed channels. How does one turn off this feature which I inadvertantly activated? Aiyeeeeee!
EAFrizzle
I just had the same accident on my 325. When it gets to the search band you want to go away, hit HOLD, then FUNCTION, then L/O. You can also scroll through the search banks and scan groups to lock or unlock them.
BinaryMode
2600 dialtone blvd
If I'm reading your post right it sounds like you have a service search or custom search band assigned to a system.
Menu.
Search for...
Edit Service.
Pick the service search that's being scanned. i.e Public Safety.
Search with Scan.
Set Quick Key.
Make it a decimal (.) to omit from the system/s you're scanning.
Consequently, you can also search up to 10 custom search ranges along with your programmed systems.
Menu.
Search for...
Edit Custom.
Chose the Custom search range 1 though 10.
Search with Scan.
Set Quick Key.
Set it as a decimal (.).
This may be a process of elimination, but with these instructions you now know how it works.
Refer to my post here on a quick low down on how to manually program.
I can't even... LOL
When I got my first digital capable scanner in circa 2004 I just dove right in. Seldom ever using the manual. Even today with my P2's I bought on eBay. LOL In a nutshell I'm pretty damn technically inclined... Do you wanna know how to use bleed air from the APU in a 737 to start the engines? I can even show you how to program the damn FMC/FMS (Flight Management System) And when I'm playing Call of Duty I like to bake cookies in the adversary's rear end HAHAHA!
