Win500: programming federal
jah377
I would like to program some federal frequencies (Border Patrol, etc.) using Win 500.
1) how do I do this without having to identify a "State" then a "County" since it won't show me federal frequencies, or
2) how can i manually enter frequencies using Win 500
Thanks for any help...
Spitfire8520
Might be slightly less clueless! =)
Colorado
I think after you select "Country" there should be an option under "State / Province" for Nationwide frequencies. I have not had a need to do an import in a while, so pardon me if this is incorrect.
Go into the "CONV Objects" and use Edit > New Item at end (Ctrl+Shift+N). You can then edit that to whatever you want.
jah377
I still don't see how to do it as a web import, but your help on the manual programming helps. I will just try that. Thanks for your suggestions!
DJ11DLN
Mudhole, IN
I hope I'm not going out in left field here, I won't be near my computer with Win500 on it before late Sunday, but I think when you look through the State list, there is an "unknown" entry in that list, and if you select that, you'll find the Fed stuff.
Sorry if my memory is playing tricks.
