Programming help VX-351
LowderK
LEO / Paramedic
Western Oklahoma
Ok I have 4 VX-351 non display handhelds that I can not get to program I have the FIF-12 and cables and CE86 but nothing when I try to read or write to the radios….. I used FIF-12 yesterday no issues on a EVX radio so I know it’s good….. also the radios are non display …. Any help and thanks in advance
radiotweester
Oregon
I'm guessing compatibility issue as CE86 Version 3.05 is from 2015. Try an actual Windows 7 machine. I doubt this will work, but try setting the program compatibility.
MBill
Some things to check:
1. In the CE86 menu go to "File". In the drop down menu go to "Configure". In the "Com Port" box it should say
"Com4 (FIF-12)" . If not you can change it. The baud rate should be set to 9600, though you may have to change that
depending on your computer. Note; You could have a different Com Port depending on your computer.
2. Open the Device Manager in your computer scroll down to Ports (Com & LPT). One of the listings should
read "Vertex Standard FIF-12 (Com4). You may have a different Com Port listed. Again depends on your computer.
3. Make sure the radio is turned off before you try to read radio.
4. I assume you do have the driver for the FIF12A installed.
There is a chance you could have a cable that doesn't work with either the FIF12 or your computer when programming
the VX-350 radios.
I've programmed the VX350 series on both windows 10 and 11 with the FIF12 with no issues.
Hope this helps.
Bill
