Programming Help
Cactus2
Santa Fe, NM
Could somebody Share with me a Simple step by step list of Process How to Add a New P25 System to my G4, I am not in need of any Tones, Lights, extras. Just How to set up a New Profile, created from RRDB, I am a Member, or mamually, enter data, save and send to G4. I have tried and watched many videos and not got it right. Please Email direct to Me at CLJERICHO@HOTMAIL.COM. Thank you very much. it is frustrating to this Newbee?
jtwalker
Gettysburg, PA & Fenwick Island, DE
YouTube is your friend. Way too much for anyone to type a comprehensive set of instructions for you, unless they have already done so.
Also could go here to the profile sharing tab and download what others have done to learn from. Unfortunately this won’t help you learn how to use latest version of PPS (0.4.0) because the public resources don’t get exported with a profile.
PPS 0.4.0
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
Perhaps someone in your area could share their codeplug with you? Sorry, not from your area nor do I have a G4
There is no simple process to programming a Unication. But what versions of the PPS are you using, it makes a difference on how you program it
Thank you so much, i am not able to open or send file to my G4, Can you advise on process? Much appreciate.
Keep in mind, the file @FishScan sent you was prepared using PPS 4.0.36, to ensure it works please make sure your PPS version is the same. Download the file, unzip it, remember where it is on your computer. Once you are on the proper PPS V36, go to tab F then F1, top of page select the file from where you saved it, click on it and select IMPORT at the bottom.
You now go to Tab E and select the file, and go to EDIT to open it. Next attach the pager to the computer once it is recognized go to program and make the proper selections to program the pager.
Good luck!
