Unication G4 Programming help request
You should now go to tab E4 click ADD and select all protocols in the drop down menu (one at a time) no other changes are needed.
Next go to E7 name the zone if needed, double click on the knob position you'll get a pop up box for RECEIVE MODE select Trunking TG Scan, and name the knob position, click OK.
Look for P25 Trunking System and select the system you entered in E2 from the drop down.
Look for P25 Trunking Protocol and select P25 Trunking from the drop down.
Scroll to the Talk Group List (near bottom) and select the TGs you want, I suggest you don't use the priority box unless you really want to as it will cause drop out of traffic on other TGs when it checks for priority TGs.
Repeat as needed
Firegoat1251
Muskegon, Michigan
I will be happy to help, but please remember I'm not sitting at the computer 24/7, I will respond as I am available.
1. Go back to tab E select the profile from the pager, and click on EDIT (bottom left), no need to connect pager yet.
2. In the new screen that opens go to tab E2-1 and click on ADD and select Add from system resources, your entries on C1 should show up, add them to E2.
Let me know when you have this done.
Yes Sir, I completely understand that you are not sitting there on standby.
I am more than happy to wait for your help, as all of you instruction so far i have understood and have worked as you said they would.
You have been an Amazing help so far and i am mor than great full.
Also i have done as you instructed above and i DO NOW have those things in my E2 Tab.
See attached image:
See attached image:
After you complete POST #21 instructions you can now connect the pager, program it and test it.
Go to E19 and select program.
Later you can fine tune it and add other options.
Beyond the above you should read through the Unication thread, below are some of my favorite posts in the forums, beyond this please ask your specific questions here and someone will respond...
Firegoat1251
Muskegon, Michigan
Repeat as needed
Firegoat1251
Muskegon, Michigan
Dear RaleighGuy, You Sir are awesome!!! I followed you instructions step by step and sure enough i have a working scanner!!!
I am very happy with this and i am i your debt.
I do need to do some adjusting and moving a few things around but feel you have provide me with the knowledge to at least try on my own.
Thank you so much for all your time and effort. I greatly appreciate you and your time.
Thank you again Sir,
Feel free to ask questions here if needed. I'm glad you are trying on your own, but I want you to go back to Tab E in the other (original) screen and export what you have now. This way if you make a mistake or mess up something you will have a backup. DO THIS EVERYTIME you make changes. I just save my changes to a file with _NEW at the end so I do not have a hundred files on my computer.
K9KLC
Southwest, IL
This is great advice. Saved me once from a mistake I made programming once. Alway back up! Thanks for all your help to him and the help you have given me over the last year when I got my first Unication.
Firegoat1251
Muskegon, Michigan
Copy that. Will do.
Thanks a ton again, You were such an amazing help.
