Programming HLT-666
LakonPC
Hello, I greet you all. I have a question about programming the HLT-666 radio. It's an older piece and the support page is gone. I used to have the software, but I don't know where it went. It's some kind of clone and I would like to pair it with a Baofeng UV-5RM. Does anyone know what software would help? I've tried everything in CHIRP and it doesn't work. Thank you for any advice.
Brand HLT
Model Number 666
Type Two-way Radio
Dimensions 115*59*34MM
Frequency Range 136-174MHz,400-470MHz
Storage Channel 16
Talking Range 3-30km
Output Power 7W/2W Shift
Special Function Voice Scrambler Color
Battery Capacity 1500mAh
Features:
Output Power 7W/ 2W
Range: 3-30km
16(15+S) Stored Channels Function
CTCSS/DCS
DTMF/VOX Function
Channel Scan/Voice Scrambler
PC Programmable
Cable Copy Function
Emergency Alarm Function
Product Specification / Models
Frequency Range HLT-666
136-174MHz, 400-470MHZ
PLL Frequency Circuit Loop
MODE
F3 Form
Antenna Impedance 50 ohms
Step Size 25 kHz / 12.5 kHz
DV Voltage 5% Operation
DV 5% 7. -25 °C~+55 °C Distances 3-30 km (open ground) Channel No. 16channel (15+S) Dimensions 115(L)*59(W)*34(D)MM Weight 198G including lithium battery group Transmitter power 7W/2W Modulation distortion <5% (300KHz-3KHz) Max.Freq.Deviation <±5KHz Interference radiation ±2.5PPM Frequency stability 6dB Transmitting current <1300mA Receiver circuit Double superheterodyne sensitivity <0.18uV(12dB SINAD) Mute sensitivity <0.16uV Mute Programmable audio power >=0.6W Receiving current <100mV
AB4BF
EM93cs
Brand HLT
Model Number 666
Type Two-way Radio
Storage Channel 16
Features:
Output Power 7W/ 2W
Range: 3-30km
CTCSS/DCS
DTMF/VOX Function
PC Programmable
Cable Copy Function
MODE
F3 Form
Looks like a Bao Feng BF-888S. Chirp will program it. Possibly. Maybe?
