Programming issue TK760GH mobile
trooper1954
Tappen, British Columbia
Hi all,
Got a programming cable recently and finally got around to using it today. Problem is, I programmed the new channels into 3 seperate groups in the programming, and now I have lost the scan function in group1, which are all the RR channels here in BC. I am unable to toggle A on the front panel....when I do, an A is not added to the screen, it simply beeps. Can someone help?
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
With out having your programming file to review, it will be a hard time trying to diagnose what isn't working. Keep in mind, every button, except for the power button, can be programmed to do a host of different things.
Worst case, if you don't get a useful answer here, drop your file on a USB stick and stop over at Vella Radio in Salmon Arm. They are a Kenwood dealer, and definitely can help you out.
trooper1954
Thanks ...but I think I've figured it out... I didn't realize that scan only covers one group at a time. When I change groups, scan works fine .... I assume that if I combine the 4 groups by putting the frequencies in 1 group, scan will actually cover all of them, or is scan limited to a given number of channels?
Thanks for the response.
hill
Middle River, MD
Don't have that Kenwood model, but you need to go into the scan settings in the software.
With Kenwood radios you have the option to set scan for one zone or check a setting in scan menu settings to enable the radio to scan all zones. You need to change the setting in scan settings to muti zone scan.
In the scan settings area of the software you can set up things like the scan revert channel. All my Kenwood radios are set up to revert to selected channel when scanning, so I will always transmit on the channel I selected. You can change it to scan act different to be able to transmit on the current channel that is active in which it stops on.
kayn1n32008
Sector 001
Also keep 8n mind, that they don't cycle through the scan list fast. The more channels in the scan list, the longer it takes to go through them. So, for example, if you have ALL 35 RR channels, all 14 LD channels and all 4 LADD channels in one scan list, it WILL take a long time to scan them all, with the likelihood of missing transmissions on them really high
