Programming Motorola PM400 - Narrowbanding programming error message
admww21
Wichita, KS
I am attempting to program a Motorola PM400 UHF mobile radio. The programming software is Commercial Series Customer Programming Software - Version. R05.18.
The software will read and write the codeplug from and to my Motorola CM200 radio.
The software will read the codeplug from my Motorola PM400 radio but will not write to the radio. When writing the codeplug to the radio, the program displays :
"Error # 2440
Due to FCC Narrowbanding regulation, only 12.5 KHz configuration is allowed.
Please contact Motorola to request a 20/25 enablement key ..."
I am not attempting to program any channels to 20 or 25 kHz bandwith. In the Conventional Personalities section of my codeplug the Channel Bandwidth (kHZ) is set ti 12.5 for all Personalities (Channels).
I have searched the softwaer in an effort to identify any other setting that might cause the Narrowbanding error message without results.
Any assistance with my program is welcome?
nokones
Sun City West, AZ
"Error # 2440
Are all the personalities in the program set for narrowband. I'll check my version and see which one I have and I'll let you know. I remember something like that years ago and I think I just pushed by that.
KG4INW
Midlothian, VA
It's been a number of years since I've worked with PM400s but they're probably like the LTR capable Pro series radios in how the CPS behaved without the wideband EID. Even if none of your zone channel assignments were linked to any LTR personality, there's by default at least one in the codeplug and it has slots for the repeater assignments. They're most likely all set for 25 kHz. You can either set them for 12.5 kHz or simply create another LTR personality (that should default to 12.5) then delete the original one. At least, that's what I recall running into before!
FFPM571
Nashvillle
PM400 is strictly analog conventional
KG4INW
Midlothian, VA
Analog only, correct, but they're LTR capable as well, not just conventional. I programmed many for various customers of an LTR system when I worked for an MSS.
admww21
Wichita, KS
Thank you for replying to my posting. I appreciate your willingness to help.
Yes - All personalities are in the original codeplug are narrowband.
I FOUND A WORK-AROUND. WOO HOO!!!.
The CPS included sample codeplugs for different model radios. I loaded the sample codeplug for my model PM400 radio. I was able to clone the sample codeplug into my radio. I then read the sample codeplug from my radio into the CPS. I was able to edit the that codeplug to suit my needs and write the edited codeplug to the radio.
Everything works and I am a happy camper!!!
nokones
Sun City West, AZ
Glad it worked out for you. Anyways, my version is 5.12. I do remember it was a simple work around but can't remember what it was. Its been more then 10 years ago I had to program a couple before the narrowband mandate to effect. Also, I just learned that yesterday was the last day to access the Motorola software archives.
