Aviation_Scanner
I am learning to use the ARC536 programming software to learn how to manually program my SDS100.
I have some experience using ARC300, which is for my Radioshack Pro-164 Scanner and the UI is similar.
I was curious as how I go about programming the conventional FM frequencies listed here. Most of the frequencies in that list are NXDN.
I know you have to select the NXDN option in the software, but I am not sure if it will let you program conventional frequencies within that option.
