Programming question for icom 5061d
Kingman, ME
I have an Icom 5061d and i am trying to program in a local police department, but seem to be having some trouble.
The frequency is 158.790 the tone is 293 NAC.
When i go to put that in the RX box in my programming software i click on DTCS and then i enter 293 but then it automatically goes to 000N again.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
I believe DTCS is DPL/DCS and not NAC.
I'm not sure this model does P25???
tampabaynews
Keeping your PIO busy
Florida
Sounds like the channel is set to analog and you're trying to enter the NAC in the CTCSS/DTCS box. When the channel is set as digital, there should be a separate box to enter the NAC.
That being said, PLEASE make sure to inhibit transmit.
jeatock
090-45-50 W, 39-43-22 N
F5061D's are 6.25 KHz 4800 baud IDAS which uses RAN's, not NAC's. NAC's are typically P25, a totally different 9600 baud 12.5 KHz digital protocol that the F5061D doesn't speak.
If the 293 is indeed a DCS and the channel is analog, try entering it as 293N and make sure the channel line is either analog or mixed receive mode, and TX is inhibited.
ElroyJetson
The F5061/F6061 does not do P25 at all. It does iDas, Icom's port of NXDN.
Not the same, not compatible.
There is not even a P25 option board for that radio.
You'd need an F2721D with the UT-120 P25 DSP option unit and the EX-2785 J01 P25 activation software in order to have a fully P25 compatible radio.
NAC is not the same as DPL. NAC is accesible when digital mode is selected, DPL is accessible in analog mode.
