TRX-1: programming
derevs
I have been trying to import the trunk system into 2 scanlists.
However, when I try to import the same trunk system onto another scanlist it erases the 1st scanlist.
By way of example, I import the trunk system into scanlist 2. I then import that same trunk system to scanlist 3 the trunk system in scan 2 is erased.
Is there a work around for this?
troymail
Silent Key
Use the EZ Scan software, import the system once, and then use the Duplicate button to make a second copy of the system - then assign all of the talkgroups in the copy to a different scanlist.
