HarryWilly
- Joined
- Jul 4, 2007
- Messages
- 272
- Reaction score
- 20
I am trying to get a P25 monitoring station on the cheap using old scanners and a more or less junky computer. So I have a couple of questions:
1. Does the radio need to support P25 in order to decode the trunk channel stream or will any radio with a discriminator tap work?
2. If you use one of the supported radios (I haven't looked yet, but I assume it uses supports non-p25 ones) can you feed a discriminator tap'd feed to a program on your computer to decode the audio as the program flips channels to monitor an active conversation?
I know it might be easier to use a digital scanner in this situation, but I don't have one yet (don't have many systems I have to hear). I know when I get one *cough* BCD996XT or whatever they call it *cough* it will be a mobile install, so I thought it might be easy to use old equipment I have lying around.
Thanks in advanced.
P.S. if someone such as UPMan were to see this - Black face please!!! And multiple backlight like on the BCD396XT!! It will look better on more mobile installs.
Thanks in advanced.
