Proscan and WME 9
res5cue
Marshalls Creek, PA
Hoping someone can help me out here.
I have the latest version of proscan. Its not registered yet cause i wanna see if I like it and all. IT says thats its fully operational for 30 days.. ok..
I have the Virtual Controller running and i minimize that, When i go and start Windows Media Encoder 9 I go to Broadcast a Live Event and the devices I wanna use are Video and Audio.
The problem is when I go to the drop down menu for Video the Virtual Controller isnt listed
just my webcam when its plugged into the computer. I can stream the audio just not
video. Can someone PLEASE PLEASE PLEASE help me out..
Thank you!!
Eric
KC1UA
This ain't gettin us noplace, we'll have to blast!
Marstons Mills, Cape Cod, Massachusetts
Sorry to come into this thread so late, but you have to use WME9's screen capture and then capture a portion of the screen. For this to work ProScan must run and load in the same place all the time. I'm doing it now on my ProScan test feed. You'll see scanmassachusetts.no-ip.com in the ProScan client list, but if you want to see it via the WME rebroadcast check the test feed at mms://streamwebtown.com/scancapecod . Audio and video delay is about 30 seconds from actual time as I'm pushing to a remote server, but it seems to work well.
AWiley
Charlottesville, VA
I have the ProScan program up and working but the Encoder keeps on saying that the "Input Media is Invalid". The Audio is recording correctly. Anybody have any idea?
KC1UA
Are you running XP? I should have indicated in my last post that XP seems to be the only platform that can share a soundcard's input with multiple programs.
AWiley
Charlottesville, VA
Streaming Scanner
ScanCapeCod, yes I do have Windows XP. I have a SigmaTel audio card. All I have is a Microphone in port. I have put the Microphone boost on. I don't think I have a "Line-In" port. I'm getting a "hummm". Help!!
KC1UA
Shut the mic boost off, that usually does more harm than good. If this doesn't work out for you, Creative Labs manufactures USB Soundblaster devices that are inexpensive and provide an excellent sound for scanner feeds. If you're running XP there is no reason why you can't share a single audio input for two or more programs, unless it just doesn't like your sound card for some reason.
Uplink
Los Angeles County
AWiley, these gadgets work great at getting rid of hum from your scanner to pc,
more info on this thread...
Uplink
Los Angeles County
AWiley said:
Uplink, how does this device connect between my 796D scanner and my microphone port on my computer?
It's a stereo filter so you don't have to use both sides. Just get RCA male to 1/8" plug adapters or adapter cables and put it in line between your speaker out to line input on the sound card, you might want to use an 1/8" plug attenuator cable if you use the mic input. You can get all this from radio shack or All Electronics.
