PROSCAN BCT15X Recorder Logging not populating
Yocuz
Gloucester County NJ
I just switched computer for my setup.
I have two BCT15X units, running two instances of BCT15x on one machine. For purpose of this conversation. Lets call one green and one blue.
Both the green and blue instances are set to recorder "ACTIVITIY & SKIP SILENCE".
I have one usb audio device with green inputting LEFT AUDIO and blue inputting RIGHT AUDIO. Both instances have the right and left routing set approriately and the audio is passing from the scanner through the proscan instance and out the laptop speakers.
The skip threshold bar is set and the audio level is above, but not audio logging is taking place on wither instance.
I am running 18.3.1
cg
Connecticut
There is UID Logging, History Logging and Recorder. Trying to figure out which you are referring to when you say Recorder Logging.
Are the programmed channels set to record? If not, is each system set to record All Channels?
You can get lines show up in the Recorder tab but the recordings are silent. That is usually Audio Control not set properly. Showing up in the History Logging but not showing in the Recorder is often the channel programming or the recorder being shut off.
