ProScan connecting issue
BillyBuff45
I've looked throw old threads, checked the proscan user manual. Ether I can't do what I'm trying to do or I'm missing something stupid.
I'm running two scanners off my desktop via proscan. The IP website I've created for both are working but when I go into the remote scanner over ip tap in proscan, I put my IP address in and the port number, hit start, along with client selected. It tries to connect and always comes up with a code 1 issue. Like I said, the IP address websites work still. I'm just looking to connect to the scanner via proscan to control and listen when I'm not home.
ProScan
Software Provider
Ontario, Calif.
When you say " IP website" That's the Web Server in ProScan. Correct? Is the RSOIP server running? Did you setup a router port Forwarding rule for the RSOIP?
BillyBuff45
Yes, the IP website I mean the web server. I have the port forwarding set up. But I also just noticed the audio for my bct15x is coming through on my feed for my sds200
ProScan
Software Provider
Ontario, Calif.
