My scanner (SDS200) uses this configuration and only picks up the conventional frequencies. None of the talkgroups. The scanner doesn't even show them on the screen. Any suggestions?
It does look correct, but like @jtwalker said, HCSO & ISP are on the same system, theres not really a reason to have 2 of the same system when you can put HCSO in the same one with ISP. Does that make sense?
The software doesn’t know which sites are important to you, so you have to select the ones that are. Or leave them all selected and use location control or site quick keys.
