Wow, now another twist to the "LCN finder". First, thank you for the input, but I don't use Sentinel, I use ProScan and I connect with Lan. So far, clicking "func" only stops the scan for a few seconds and if I then click "e" I just get a "beep" with no popups to save, add or anything.
Great function, but a bit difficult to make it useful?
You can just read the results back into ProScan. Either ProScan or Sentinel will do; use whichever you prefer.
You don't need to hit <Func> first before resume, to get the 'Save' prompt. Simply hit the System key.
For menu actions where you
do have to hit Func first, the display will indicate it (I forget the exact syntax, but here's the basic) "Func + Sys" for resume. (For the 436HP & 536HP, you
do have to preface the System key with Function; on the SDS scanners, just the System key alone gets the option to save.)
For choices where the Function key is required, 'Function' will only be active for a few seconds. You'll see the
F in the upper left corner of the display while it is engaged.
