PROSCAN Remote Scanner Over IP
kgowen44
Sacramento, CA
Hello,
Im trying to set up rsoip on an sds200 using proscan. I did url setup under audio control and chose scanner from auto detect. The PC seems to notice it. However,under the RSOIP button under sercer mode, I click connect.....Than i receive an error "set the input sound device to a valid input located in audio control tab" every thing is correct. Ive tried 3 pc's amd dame issue happened. Any ideas?
PC Tried
Older HP Elite book 8g ram, Windows 10, all updates done
2nd PC Razer laptop 32RAM, windows 10, up to date
Scanner is showing on proscan....just cannot start server
What could I be missing?
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
You're certain you chose the proper sound input here? (reference pages 7 & 8 of the Proscan manual to ensure you have your bases covered)
BCD536HP Wi-Fi Dongle / SDS200 Ethernet Audio Setup
4. Click the Input Sound Device combobox.
5. Choose URL.
6. Click the URL Setup button.
7. Enter the IP address of the scanner. Example: --> rtsp://192.168.1.5/au:scanner.au The IP address will be different in your environment.
8. Click the Reconnect button.
9. If successful, "TCP Not Connected" and "UDP Not Connected" messages should disappear and "Bytes RX" increment
buddrousa
Set in the audio section rtsp://192.168.1.151/au:scanner.au
Do you see on the PROSCAN Server PC the Scanner working?
Do you hear on the PROSCAN Server PC the Scanner Audio?
Under COMM PORT have you set the PORT to URL? 192.168.1.151
Whiskey3JMC
Philly burbs 🇺🇸
I have that setting correct and set to URL
When I go to RSOIP section to connect, I get error
I can't tell from your first screenshot which mode's tab you're under. Maximize the window so we get the entire picture of every tab you've clicked so I can see you've clicked Audio Control tab then RSOIP tab and have set the source accordingly as I've outlined in post #2...
