Proscan (Web Server) Audio
scorpdude
How do I get the audio to work on android or desktop browser? I have audio working but not when I want to use it as a web server. audio it coming through for local listening. I have everything set up as router. I'm running the bcd536hp. I try to hit the arrow in top left corner where it says Listen live and it does nothing. I can get to the live web server using my domain ip. no issues just audio when the page comes up
ProScan
Software Provider
Ontario, Calif.
Use an external web player. If using the built in html5 player then wait some more time after hitting the Listen Live link. That's because the network buffer has to fill up before playing.
scorpdude
I waited for a good while and it shades out when I click on it. Now for external player what would an example of a url for that? I hit the download and it does nothing in winamp and others. This is my only issue. Otherwise works great.
ProScan
Software Provider
Ontario, Calif.
If an external player is assoicated with .m3u files then the player should automatically load and play the stream.
The URL format is -> http://192.168.1.17:5000/stream
Use the actual IP Address, Port #, stream name
If the stream is password protected then it is -> http://192.168.1.17:5000/stream+password
scorpdude
Tried that just sit's at 0.00 it's not buffering or anything. I also tried it with actual ip address and same thing. what am I doing wrong? web server is on. I can see connections as in going to the web page. it shows that in the log when I log on in a web browser. just audio is the issue.
