provoice for cuyahoga county
glenn12416
cleveland,ohio
this may be a dumb question but is the pro voice upgrade worth to buy in cuyahoga county all i see is busses and parma police i can hear both without the upgrade ,it is listed as edacs i cant seem to figure it out
kb5udf
Louisiana
I skimmed the RR DB for you. I saw about 3 EDACS systems in Cuyahoga County and all of the listed talkgroups were flagged as analog.
So offhand I'd say the answer to your question is no.
glenn12416
cleveland,ohio
Thanks I just upgraded a sds100 for nxdn and i cant quite understand the EDACS or provoice differences im reading up on it now
lwvmobile
DSD-FME
Lafayette County, FL
EDACS is a trunking radio system, signalling the radio ids, groups ids, and which LCN channel to tune a radio to. ProVoice is a digital voice mode used on some EDACS systems. EDACS systems can carry both Digital and Analog voice. The only suggestion I can make is try it without first, and if you hear or see digital voice on that system, then its up to you to decide whether or not to buy the upgrade. EDACS and ProVoice are well out of support and those systems are supposedly thinning out, even if it still seem to be the main system used by SLERS in Florida.
wa8pyr
Staff member
Lead Database Admin
Ohio
Don't waste your money. There never was much Provoice used anywhere in Ohio, and none up there to the best of my knowledge. The NXDN and DMR upgrades would be far more worthwhile.
tweiss3
Is it time for Coffee?
Ohio
Agreed with the above, though it depends what you intend to listen to. Even traveling many states, I only got NXDN and DMR upgrades for the mobile scanner, and never felt like I have missed anything.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
As of this posting there are only 31 identified systems in the RR database utilizing Provoice in one way or another (some only one or two talkgroups. Basically any talkgroup ID'ed as mode "D" would be Provoice digital in these cases), see list here. If you have no intentions on monitoring any of these then I wouldn't waste money on the upgrade
