SDS100/SDS200: ProVoice
K2KOH
Silent Key
Putnam County, NY
I had my original SDS100 worked on and now have a replaced model with a different ESN. The new ESN has three more digits than a regular ESN, and the DMR and NXDN from the old radio have been cloned into this radio. I'n considering Provoice...so I now register this new ESN and go from there? @JoeBearcat
nessnet
What month is it?
Do you actually have a Provoice system/site near you that you want to monitor?
Provoice is a dying technology and if you don't have a specific system to monitor - don't bother with it...
GTR8000
NY/NJ Database Guy
BEE00
Yes, he does. Only a handful of talkgroups, but there are a few.
donc13
Grand Junction, CO
When you go to buy the pro voice key, you'll see the first 3 or 4 digits already beside the box where you enter the ESN. Do not enter the dash, the digits to the right of the dash are the checksum.
u2brent
OAMPT
KRWDPAXKRS1
Add the new/replaced scanner SN/ESN to your uniden account,
Purchase the needed upgrade for the scanner (after successfully adding it to your account)..
fxdscon
¯\_(ツ)_/¯
Both ESN's should have the same number of digits:
The electronic serial number (ESN) - available through the menu system in the scanner has 14 digits. It's followed by a dash, and then the 3 digit checksum.
The serial number (SN) - on the model label on the back of the scanner has 12 digits.
JoeBearcat
Uniden Representative
Can you clarify "The new ESN has three more digits than a regular ESN"?
Are you talking about the 3-digit checksum? (which is not part of the ESN)
The DMR/NXDN keys from your old unit will not work on the new one.
If this was a Uniden repair the new scanner should have come with those modes enabled. If it did not, contact Customer Service.
