Hey, thanks for the replies.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here’s more about my setup:
Remtronix 820S antenna -> coupler -> FM notch filter -> LNA (+20dB) -> 2x Nooelec RTL-SDR dongles. They are hosted by a Raspberry Pi using rtl_tcp. I have a relatively short USB cable going to my Raspberry Pi with ferrite chokes on each end. I have a PC running Linux using trunk-recorder to handle the broadcasting duties as the Pi couldn't keep up with the amount of recorders necessary to capture the huge amount of calls that go over PSERN. trunk-recorder uses osmosdr and gnuradio as its stack.
Since I use rtl_tcp, it means I can't use SDRTrunk since it doesn't support devices that aren't physically connected
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. Once I get a longer cable for the USB hub that has the dongles connected to it, I can try that and see if I get any better results. (I don't need a super long cable -- 6' should suffice, but my USB hub requires an oddball USB-A to USB-A cable and that's the one kind of cable I don't have in bulk.)
In my trunk-recorder settings, I've been experimenting with different gain settings on the SDR itself. I've found 16-20 seems to be a good value but I'm still tweaking things. My RTL-SDRs have a good 0.5PPM TCXO and I'm observing minimal frequency drift after tuning the PPM values in my trunk-recorder config.
I'm not sure what my noise floor is or how best to check it but I'm happy to dig into this more. I'm assuming it's not great. My antenna has to be indoors for various reasons but it's somewhat isolated from direct noise sources.
RRDB doesn't seem to have coordinates for PSERN towers so I'm not sure how close it is. When I was broadcasting KCERS, I was using the Education Hill tower which is line of sight for me. If PSERN is using the same infrastructure, then it's definitely close
Here’s my feed if anybody wants to listen and tell me if it really sounds as bad as I think it does:
OpenMHz.
