PSR-500/600 1.3 software
emscapt9816
Retired, but somehow working harder now...
Coconut Creek, FL
What Am I missing?
OK, I downloaded the firmware to my desktop. What program do I use to upload it to the radio?
thewenk
Idaho DB Admin
Eastern Idaho
No other software needed, but you need to have communication from your PC to your scanner through the USB scanner cable that came with your scanner. Read the instructions that came with the download and then double click GRE CPU Icon and follow the onscreen instructions.
Dave
emscapt9816
Coconut Creek, FL
Dave
I have communication, I just downloaded V-folders to the radio. I click the "open" box on the download window, it downloads, then disappears. No instructions, nothing. When I saved to my desktop, I double-clicked on the file, and nothing happens.
I must not be getting the whole file. The download dialogue box says "CPU500600_U13.1.2D0D17.efw"
tglendye
Blue Ridge Mountains, Shenandoah River
I'm not the best one to answer your question, but you need to unzip the downloaded software with a program such as "winzip". I just downloaded the update to my scanner and it went pretty well.
gmacka
Sydney N.S.W ( south west )
In regards to upgrade of software for GRE500
1-How do i check to see current version on scanner?
2-Could some 1 walk me through on how to upgrade new versions to my scanner?
I have visited GRE web site but find all a little confusing.
If some 1could please help me i really appreciate it.
kind regards gmacka
spooney
Indiana
Turn the scanner on and press 3 immediately to see firmware version. if it doesn.t read: uP Appl Ver: U1.3 , then you need to download the file from GRE website v1.3 and save it and open it and follow the instructions closely.
gmacka
thxs 4 reply spooney
my scanner shows
Up Appl Ver. F1.1
DSP App Ver. F1.1
DSP voc Ver.F1.0
is that what should be on there before i add new file?
spooney
Indiana
my scanner shows
Up Appl Ver. F1.1
DSP App Ver. F1.1
DSP voc Ver.F1.0
Ok, for the above versions download and install the PSR-500/600 CPU Firmware version F1.3 first. Then download and install PSR-500/600 DSP version F1.2
Be sure to follow the instructions closely as the steps are a little different from CPU to DSP
installations. After you are done the screen should read:
uP Appl Ver: U1.3
DSP App Ver: U1.2
DSP Voc Ver: F1.0
Just make sure you have the COMM port number your computer is using for the USB programming cable because the instructions require that you select the COMM port number during the installation. Good Luck!!
cookmaster
Tucson,Arizona
well as far as the new downloads, it says in the Owner's Manual on page 90 to Hold PGM while powering on radio. Places radio in CPU firmware upgrade mode. do i need to this before the new Downloads. thank you.
DonS
Franktown, CO
When you run the upgrader program from the GRE America web site, it will give you step-by-step instructions
usswood
Terre Haute, IN
trying to upload DSP ver 1.3 keep getting error...how can i erase CPU ver1.6 so i can upload the DSP first then the CPU
