PSR-500/600 PC-IF trunked decoding
John
Roanoke VA
mtindor said:
On the PSR-500, using the PC/IF cable instead of tapping the scanner, Unitrunker supports Mot 3600. It will support LTR/EDACS as soon as GRE issues a firmware update that includes the fix for some problems with their EDACS/LTR output. I am unsure if Unitrunker supports 9600 P25 at this time or not.
As already mentioned by others who know more about it, Pro96Com handles 9600 P25 via the PC/IF cable.
So, between the two programs you have all of the options covered (or will once GRE releases updated firmware that has the fix in it).
Mike
I am not that familiar with Unitrunker but I can't seem to get it work with my PSR500 and a Moto3600 system. I don't get any data displayed. Th eonly setting I see in the setup is for sound card type inputs. What should it be set to to use the USB SPR cable?
John
Configure the program like this. The example shows "COM1". Set it to whatever COM port your computer has associated with the USB cable. If you have any more questions - please post them under the Trunker/ETrunk/T4Win forum.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
John
Also, make sure you have CCDUMP turned on. FUNC, then GLOB, then scroll down to CCDUMP and enable it, then press F1 for SAVE.
To be sure you get to the right menu, do it this way:
MAN, then PGM, then FUNC, then F3 (for GLOB), then arrow-down until you get to the bottom. You'll see CCDUMP. Make sure it is turned ON. If it off, then turn it ON. Then press F1 for SAVE.
Mike
