PSR-500 Problem
FJB2022
When the scannner is scanning and it stops on a trunked talkgroup I can't see what talkgroup
im listening to because it flashes so fast I only see the system im listening to and not the talkgroup. For example if im listening to Chesaeake and it stops of Fire Dispatch it blinks so fast I only see Chesapeake and I can't tell what im listening to so I need to figure out how to slow it down. Everything was working fine before I read the scanner and wrote it with PSR Edit V1.46, I have been using PSR Edit V1.41 till tonight and I can't figure out why its doing this. I clicked reset all global settings and loaded my old files but nothing changed, I also did the latest 1.2 firmware updates the other day and everything worked fine after that. Anyone know how to fix this? Thanks
-Jeff
mikey60
Oakland County Michigan
-Jeff
It appears that there is an issue in PSREdit version 1.45 and 1.46 that causes this. The only problem with getting it fixed is that it doesn't happen on my machine. It has to do with the LCDBlink On and LCDBlink Off settings.
For the moment if you have it and are seeing this problem, I would suggest going back to 1.44.
I'm going to be doing some traveling over the next couple days, so I won't be able to address this for sure until Sunday or Monday.
I'll upload the 1.44 version to the site again shortly so that people can get at it if they don't have it.
Mike
FJB2022
Sounds good. Thanks.
N4DXX
In the pines where the sun never shines
Mike
Same problem here mike even after going back to 1.44 but i suppose i loaded a file that was created with 1.45 all i done to correct the blinking was lcd blink on 125 and lcd blink off 50 and it seems to work fine..
FJB2022
Those settings work great. Thanks
-Jeff
