I'm trying to decode a P25 digital system on my PSR-500. I have all the control channels programmed, I have set the system type to "P25 Auto", but the scanner will not decode the control channel (P25 conventional frequencies work just fine, and it also works just fine on analog trunking systems). When I set the scanner to analyze the control channel, it won't, although the signal strength meter shows a strong signal is present. My PSR-800 and my BCD396XT work just fine on this same system.
The system in question is in Broward County, Florida, listed in the database as, "Broward County Public Safety (Project 25)".
So, I'm thinking it's an incorrect setting I'm missing somehow. I don't need any custom tables, do I? I've checked out everything I can think of.
