New U1.8 firmware is available for the PSR-800.
Version U1.8 - January 15, 2013
Added ability to decode APCO Project 25 Phase 2 TDMA voice channels. This version must only be used in conjunction with DSP firmware version U1.3 or later.
When this version is installed, the uP Appl Ver line on the version screen (accessed by pressing the MENU when the welcome message is displayed after a power up) will show as version 1.8.
When a Phase 2 talkgroup is active, the scanner will display "D2" instead of "DG".
We recommend ensuring the sites on a P25 Phase 2 system be set to Auto-Fill mode. This will allow the scanner to automatically set the information needed to track the system from the control channel data stream. Don't use "custom tables" for Phase 2 systems unless you really know what you're doing.
Added support for decoding of radio ID and priority channel detection since the release of Beta 2.
Fixed issue in the Beta 2 versions with the scanner not returning to the control channel when a Phase 2 transmission ends when the other time slot is in use on the same frequency.
