PSR-800 Firmware U1.8
vince48
Central Valley, CA.
Go to Updates then Configure Proxy Server and make sure the Enable Proxy Server Support box is not checked, then try updating again.
Dear Sir, did that so many times , still get error.
I can within EZ scan - Help menue click "visit GREAmerica.com" I connect
to the website
using help menu in EZ scan click "GRE Support" I connect to the website
using help menu in EZ scan click " Visit RadioReference.com" I connect
to the website
I give up, nothing is blocking in my system (software, hardware, router)
vince48
Lincoln, NE
to the website
to the website
vince48
try un-installing and re-installing??
W2GLD
Michigan
Yep! I just went from v1.6 to v1.8 with no troubles at all... EZ-Scan updated without incident as well from v1.06 to v1.08. I updated the EZ-Scan software first, followed by the firmware and lastly the DSP.
KE5TLF
MS Gulf Coast
Seems little, to nothing, done about the volume disparity between FDMA and TDMA. :(
Bittersweet that they've made this an offical release too. Doesn't bode well for the process of further improving things.
KD4YGG
Just wondering if you were to select Audio Boost to the FDMA-only talkgroups if that would equalize the audio level with TDMA-only talkgroups??? Don't know specifics of the system you're monitoring and if the talkgroups of interest are dual-mode FDMA/TDMA or not.
Just a thought on a possible workaround...
dominator612
Banned
Melbourne, FL
I am still seeing that they are making improvements with this release which makes me scratch my head at your post.
I am going to purchase the PSR-800 just as soon as I can.
KE5TLF
MS Gulf Coast
Yes they're dynamic, so any potential per talkgroup fix, would seem to be useless as it would effect both TDMA and FDMA.
Have you submitted a ticket to GRE explaining the issue? :confused:
Mentioned by myself and others several times during the beta testing phase, which seemed to be more than enough to get all other identified issues addressed.
bravo14
Polk County FL
I updated it and no problems at all. Of course no Phase II by me just did it for the heck of it. I didn't update on the cpuudater u1.7 I wonder the new firmware 1.8?
GTR8000
NY/NJ Database Guy
BEE00
I wouldn't rely on mentioning issues in threads on RR to get GRE's attention. If there is a known issue with the firmware, which there seems to be, create a ticket in GRE's support system and you will get a direct response from them.
