I have a PSR-800 that was working perfectly until a couple of days ago.
I have not made any changes to it or updates, etc.
I have been using it only to do Unitrunker testing.
It has been plugged and unplugged from the pc USB port many times.
I have been powering it only from the USB port. The batteries were removed.
The problem that developed is there is no audio on any of the scan lists
that are in P25 trunked systems. The scanner scans and has the cc and a
good signal strength. The display shows exactly what it should.
But there is no audio on trunked systems.
I built a conventional scan list for HAM radio 2-meter repeaters and that
works great. It scans OK and there is audio on the conventional frequencies.
Also the Skywarn button plays the NOAA NWS channel info with good audio.
I re-formatted the SD card and did a complete download from pc to scanner
using the EZ-Scan software.
SO...I have audio on conventional systems and no audio on trunked systems.
What am I doing wrong?
teknishun
teknishun
