I have a PSR-800 that I've had for about a year. Hadn't had any problems until this summer, when I started realizing that my scanner was shutting off after running only about 15-20 minutes when it was powered with batteries. It makes no difference whether it's alkaline or nimh - it's the same either way. It will run with no problems and then just shut off. I looked at the logs and can see the voltage drop dramatically within a few minutes. I put brand new AA Duracell batteries into it, thinking there would be no way it would act up with good alkalines, but it still does it. This may help -- If I simply turn it on in menu mode, it won't decrease the battery. But if I start stepping through recordings or scanning actual transmissions, it decreases dramatically and then shuts off. I'm attaching a copy of the logs so you can see what I'm talking about. Does the scanner automatically shut off somehow? I noticed that in the first log, when I didn't power off the scanner but it shut off on its own, it didn't even reach the alert battery level.
Here are my battery values:
14 bars - 4.80 5.26
12 bars - 4.70 4.98
10 bars - 4.60 4.80
08 bars - 4.50 4.68
06 bars - 4.40 4.57
04 bars - 4.30 4.47
02 bars - 4.20 4.34
00 bars - 4.10 4.21
*ALERT - 4.08 4.08
LOG #1 -->
2012-11-28 13:16:16
2012-11-28 13:16:16 Power up!!!
2012-11-28 13:16:16
2012-11-28 13:16:16 BattLevel: 488 488 488
2012-11-28 13:16:16 IconState: 12
2012-11-28 13:16:21 BattLevel: 485 463 463
2012-11-28 13:16:26 BattLevel: 483 463 464
2012-11-28 13:16:31 BattLevel: 479 451 451
2012-11-28 13:16:31 IconState: 10
2012-11-28 13:16:36 BattLevel: 476 451 454
2012-11-28 13:16:41 BattLevel: 471 447 447
2012-11-28 13:16:46 BattLevel: 468 447 452
2012-11-28 13:16:51 BattLevel: 464 447 448
2012-11-28 13:16:51 IconState: 8
2012-11-28 13:16:56 BattLevel: 460 447 449
2012-11-28 13:17:01 BattLevel: 456 447 448
2012-11-28 13:17:01 IconState: 6
2012-11-28 13:17:06 BattLevel: 453 447 457
2012-11-28 13:17:11 BattLevel: 452 447 457
2012-11-28 13:17:16 BattLevel: 451 447 454
2012-11-28 13:17:21 BattLevel: 452 447 457
2012-11-28 13:17:26 BattLevel: 452 447 453
2012-11-28 13:17:31 BattLevel: 453 447 457
2012-11-28 13:17:36 BattLevel: 453 447 453
2012-11-28 13:17:41 BattLevel: 454 447 455
2012-11-28 13:17:46 BattLevel: 454 447 454
2012-11-28 13:17:51 BattLevel: 455 447 454
2012-11-28 13:17:56 BattLevel: 455 447 456
2012-11-28 13:18:01 BattLevel: 454 447 452
2012-11-28 13:18:06 BattLevel: 454 447 455
2012-11-28 13:18:11 BattLevel: 454 447 451
2012-11-28 13:18:16 BattLevel: 454 447 454
2012-11-28 13:18:21 BattLevel: 452 442 442
2012-11-28 13:18:26 BattLevel: 451 442 444
2012-11-28 13:18:31 BattLevel: 451 442 452
2012-11-28 13:18:36 BattLevel: 450 442 443
2012-11-28 13:18:41 BattLevel: 450 442 451
2012-11-28 13:18:46 BattLevel: 448 442 442
2012-11-28 13:18:51 BattLevel: 447 442 443
2012-11-28 13:18:56 BattLevel: 446 439 439
2012-11-28 13:18:56 IconState: 4
2012-11-28 13:19:01 BattLevel: 445 439 442
2012-11-28 13:19:06 BattLevel: 444 439 448
2012-11-28 13:19:11 BattLevel: 445 439 450
2012-11-28 13:19:16 BattLevel: 445 439 449
2012-11-28 13:19:21 BattLevel: 445 439 449
2012-11-28 13:19:26 BattLevel: 446 439 450
2012-11-28 13:19:31 BattLevel: 446 439 448
2012-11-28 13:19:36 BattLevel: 447 439 452
2012-11-28 13:19:36 IconState: 6
2012-11-28 13:19:41 BattLevel: 447 439 447
2012-11-28 13:19:46 BattLevel: 448 439 450
2012-11-28 13:19:51 BattLevel: 449 439 447
2012-11-28 13:19:56 BattLevel: 449 439 449
2012-11-28 13:20:01 BattLevel: 448 439 448
2012-11-28 13:20:06 BattLevel: 448 439 448
2012-11-28 13:20:11 BattLevel: 448 439 449
2012-11-28 13:20:16 BattLevel: 448 439 447
2012-11-28 13:20:21 BattLevel: 448 439 450
2012-11-28 13:20:26 BattLevel: 448 439 446
2012-11-28 13:20:31 BattLevel: 448 439 449
2012-11-28 13:20:36 BattLevel: 447 439 446
2012-11-28 13:20:41 BattLevel: 448 439 448
2012-11-28 13:20:46 BattLevel: 447 439 446
2012-11-28 13:20:51 BattLevel: 447 439 447
2012-11-28 13:20:56 BattLevel: 447 439 448
2012-11-28 13:21:01 BattLevel: 447 439 446
2012-11-28 13:21:06 BattLevel: 447 439 449
2012-11-28 13:21:11 BattLevel: 446 439 444
2012-11-28 13:21:11 IconState: 4
2012-11-28 13:21:16 BattLevel: 447 439 448
2012-11-28 13:21:16 IconState: 6
2012-11-28 13:21:21 BattLevel: 446 439 443
2012-11-28 13:21:21 IconState: 4
2012-11-28 13:21:26 BattLevel: 446 439 447
2012-11-28 13:21:31 BattLevel: 446 439 445
2012-11-28 13:21:36 BattLevel: 446 439 446
2012-11-28 13:21:41 BattLevel: 446 439 447
2012-11-28 13:21:46 BattLevel: 445 439 444
2012-11-28 13:21:51 BattLevel: 446 439 447
2012-11-28 13:21:56 BattLevel: 445 439 443
2012-11-28 13:22:01 BattLevel: 445 439 447
2012-11-28 13:22:06 BattLevel: 445 439 442
2012-11-28 13:22:11 BattLevel: 445 439 446
2012-11-28 13:22:16 BattLevel: 445 439 444
2012-11-28 13:22:21 BattLevel: 444 436 436
2012-11-28 13:22:26 BattLevel: 443 436 437
2012-11-28 13:22:31 BattLevel: 442 436 443
2012-11-28 13:22:36 BattLevel: 442 436 437
2012-11-28 13:22:41 BattLevel: 440 434 434
2012-11-28 13:22:46 BattLevel: 441 434 444
2012-11-28 13:22:51 BattLevel: 439 431 431
2012-11-28 13:22:56 BattLevel: 439 431 444
2012-11-28 13:23:01 BattLevel: 439 431 441
2012-11-28 13:23:06 BattLevel: 438 431 434
2012-11-28 13:23:11 BattLevel: 438 431 444
2012-11-28 13:23:15
2012-11-28 13:23:15 User power down!!!
(SCANNER POWERED OFF ON ITS OWN)
LOG #2 -->
2012-11-28 15:30:15
2012-11-28 15:30:15 Power up!!!
2012-11-28 15:30:15
2012-11-28 15:30:15 BattLevel: 484 484 484
2012-11-28 15:30:15 IconState: 12
2012-11-28 15:30:20 BattLevel: 481 459 459
2012-11-28 15:30:25 BattLevel: 478 449 449
2012-11-28 15:30:25 IconState: 10
2012-11-28 15:30:30 BattLevel: 475 449 458
2012-11-28 15:30:35 BattLevel: 472 449 456
2012-11-28 15:30:40 BattLevel: 470 449 459
2012-11-28 15:30:45 BattLevel: 467 449 454
2012-11-28 15:30:45 IconState: 8
2012-11-28 15:30:50 BattLevel: 464 449 457
2012-11-28 15:30:55 BattLevel: 461 449 452
2012-11-28 15:31:00 BattLevel: 458 449 457
2012-11-28 15:31:05 BattLevel: 455 449 453
2012-11-28 15:31:05 IconState: 6
2012-11-28 15:31:10 BattLevel: 454 449 454
2012-11-28 15:31:15 BattLevel: 455 449 452
2012-11-28 15:31:20 BattLevel: 454 449 450
2012-11-28 15:31:25 BattLevel: 454 449 453
2012-11-28 15:31:30 BattLevel: 453 449 452
2012-11-28 15:31:35 BattLevel: 453 449 455
2012-11-28 15:31:40 BattLevel: 452 447 447
2012-11-28 15:31:45 BattLevel: 452 447 454
2012-11-28 15:31:50 BattLevel: 452 447 451
2012-11-28 15:31:55 BattLevel: 452 447 452
2012-11-28 15:32:00 BattLevel: 452 447 454
2012-11-28 15:32:05 BattLevel: 452 447 452
2012-11-28 15:32:10 BattLevel: 452 447 454
2012-11-28 15:32:15 BattLevel: 452 447 450
2012-11-28 15:32:20 BattLevel: 452 447 454
2012-11-28 15:32:25 BattLevel: 451 447 449
2012-11-28 15:32:30 BattLevel: 452 447 453
2012-11-28 15:32:32
2012-11-28 15:32:32 User power down!!!
(THIS TIME I ACTUALLY POWERED IT OFF)
14 bars - 4.80 5.26
12 bars - 4.70 4.98
10 bars - 4.60 4.80
08 bars - 4.50 4.68
06 bars - 4.40 4.57
04 bars - 4.30 4.47
02 bars - 4.20 4.34
00 bars - 4.10 4.21
*ALERT - 4.08 4.08
LOG #1 -->
2012-11-28 13:16:16
2012-11-28 13:16:16
2012-11-28 13:23:15
LOG #2 -->
2012-11-28 15:30:15
2012-11-28 15:30:15
2012-11-28 15:32:32
