My PSR 800 is not functioning. Anyone have a lead on any current repair facilities or persons? Thought I saw someone that was offering repair but can't place it.
Regards, Mark
Regards, Mark
Try -My PSR 800 is not functioning. Anyone have a lead on any current repair facilities or persons? Thought I saw someone that was offering repair but can't place it.
Regards, Mark
Ditto!What's the issue?
Wish I had that much talent to hack.....lol. Thanks!If you are referring to the GRE 800 hack to make it a 1080, forget it. You will end up bricking your radio. Only sending it to Whistler to upgrade the radio to a Legacy 800 was the safe way. Those days appear to be over with Whistler out of business. If you are alluding that you already tried the hack then you may have bricked your radio. You can still update the programming of frequencies and talkgroups and systems by manually entering through EZScan and uploading to radio. But if you bricked your radio you need to buy a legitimate used Legacy 800.
If you have the PSR-800 EZ Scan programming software, you can program the scanner manually using the information in the Radio Reference database.Won't scan have old data from their web site library. Want to load Prince William County & Fairfax County VA.
Tvengr I am glad you clarified what I told the OP!If you have the PSR-800 EZ Scan programming software, you can program the scanner manually using the information in the Radio Reference database.
