PSR500/PSR600: PSR600 won't take SAME code
scannerX
Minnesota
My PSR600 absolutely will not accept weather SAME codes. I must be doing something wrong but what?? The display is there for entering SAME codes but the curser just blinks at me when I try to enter a code such as 027053. Any help would be very much apprecated.
Dale j.
scannerX
Minnesota
Thanks, but on my PSR-600 entering in the code like you discribed doesn't work. The curser just blinks. Must be something wrong with this radio. It picks up the NOAA weather loud and clear but programming in the SAME codes just doesn't work.
fxdscon
¯\_(ツ)_/¯
Will the scanner accept a SAME code if you program it with software?
scannerX
Minnesota
Just checked my Butel ARC500, under global settings, there's a weather tab, has a programing widow for "fips codes".
Not sure if that's what your looking for?
No, I was trying to enter the SAME codes using the internal program feature and buttons on the front panel. I resorted to win500 and entered them with it. I don't always have access to a computer and was wondering what I was doing wrong when all I got was a blinking curser when at the window for entering S.A.M.E. codes. I have the user manual and followed it item by item.
krokus
Southeastern Michigan
SAME uses the FIPS codes for identifying the county. From a user perspective, they are synonymous.
scannerX
Minnesota
Thanks. I was able to input the SAME codes using WIN500. I don't know why I was not able to do it without a computer though. I should have been able to enter the codes from the front panel of the radio, A PSR-600.
