Purchased the TIDRadio TD-3H, and attempted to use the charging/programming cable with CHIRP. All the ports on my laptop come back with a message abou
Holdmonkey
Bryceville
Purchased the TIDRadio TD-3H, and attempted to use the charging/programming cable with CHIRP. All the ports on my laptop come back with a message about not finding the comm port. I borrowed a programming cable which DiID work. Is this a "thing" with that cable?
K6GBW
Montebello, CA
Are you using Windows 11? If so it’s likely the OS is blocking it from using the proper driver. The fix is to disable hardware security in settings and then use device manager to select the needed driver.
Holdmonkey
Bryceville
No, my OS is Windows 10. Thank you for replying, though.
