Kenwood: Q on kenwood tm-d710ga mic use
ke2dzk
Hello all, I'm new to ham radio and blindly bought a kenwood tm-d710ga on a whim and trying to learn how to use it.
Basic question on the mic keypad ... is there any way to use the keypad to directly enter a VFO frequency or directly enter a memory channel?
At least on my unit, I can't figure out how to do this. Did a full factory reset and can't find any menu items that would lock the keypad.
Thank you
AK9R
Super Moderator
Central Indiana
Any of the four programmed function keys on the microphone can be reprogrammed:
Here is the explanation of how the keys can be set:
Here is the explanation of how direct frequency entry works. Note, this also works for direct memory channel access when in Memory mode:
ke2dzk
Brilliant ... thanks!
It's a wonder why memory/VFO direct entry is not a default setting for the mic. I was able to reprogram the call button to [enter].
Thanks much
AK9R
Super Moderator
Central Indiana
I usually PF4 (CALL) to ENTER and PF1 (PF) to REV so I can quickly check the input while listening to a repeater frequency.
Why it doesn't come from the factory like that? Who knows. I'm just glad they let us change it.
