QC2 over p25t
hfd26
I'm trying to setup a knob postion with 15 tgid (fire/ems disp,fire/ems ops,LE)with 9 two tone ids. I want the fire/ems as priority so it will decode the two tone, do I have to enable tgid pri or multi select? When I monitor this knob postion and anouther channel is talking the pager doesn't seem to switch to the priority(fire/ems disp) fast enough to get the two tone, and if it does get the two tone it will only do 1 set of two tones. Watching the video they don't select priority tg or multi sampling,so I'm wondering how won't miss a two tone. A separate knob postion with only fire/ems disp selective call works but again sometime will only do 1 set of two tones for ems but not first responders. In my sub group I have all of them enabled.
emtLarmy15
Pocomoke City, MD
Your looking at a couple things... you need to have your revert settings with all the other tones you want to activate.
In reference to dispatch priority is it the highest in your talkgroups list on the knob selection?
hfd26
All of the two tones are enabled in the revert list and the fire/ems is at the top of both list
emtLarmy15
Pocomoke City, MD
Do you have alternatives checked for your revert?
I would tell you to send me your pps but I won’t be able to look at it until tomorrow morning at the earliest.
hfd26
Yes alternative is enabled in revert. I noticed in the video he didn't click tgid priority or multi select call sampling. Right now I have priority enabled and the pager will switch over but doesn't always decode the two tone. I tried reading about the multi select call sampling on the right side of the page but don't really understand what it means or does.
