Quantar Multi-PL - NO PL on TX
W4UO
Kodak, TN
Having an odd issue with Multi-PL mode. I have 2 users in the table, both with the same TX PL. Quantar will RX either PL set for each user but will not TX a tone. Set user radios to CSQ on RX and everthing is passing through.
Wildcard is turned off, no values are present in the TRC tables. I feel like this is something easy that im missing.
Multi-PL User table is USER 1 RX 141.3 TX 103.5 and USER 2 RX 103.5 TX 103.5 ...
W4UO
Kodak, TN
ff026
ff026
I had disabled wildcard. Ill look through the manual and see. This quatar has a sam installed. would this possibly be a culprit?
Also with the standard single tone rx/tx ,multi-pl disabled, it works fine.
I think wildcard needs to be enabled. There also might be something in the SAM module that needs to be configured. Been a long time since I messed with a quantar.
