K6CV
Hi all, A Newbie to Quantar's at this end. I'm trying to get my SCM to talk properly to the 8WL card I have, and for the life of me, cant get the 50pin Aphenol connector to accept a PTT ground signal from a URIx AllStar node. This points me to the model numbers of the Quantar cards I have, and they may not be able to talk to each other due to dependencies in manufacture dates.
For the record, I have:
SCM Module: CLN6961D
8WL Module: CLN6883B
Q: Are these compatible?
When I power up my recently acquired this UHF Quantar, it does it's normal blinking lights, and the Exciter comes up with TX Lock which is green (good)
The SCM Module downloads some firmware code ( I guess) to the 8WL card, but then it's Station On light is solid green, but it also has the AUX LED blinking Green at me, and the WL card itself, alternates between the Red and Green led's on that card every few seconds.
This is telling me that something is not kosher with this setup.
I have looked and looked for these module number on the 8WL card at various sites, but come up blank.
I do believe my SCM Module is a EPIC II card, requiring a EPIC II WL Card, but finding this 'CLN6883B" information turns up a dead-end.
Just trying to get my AllStar node to key the Quantar and pass audio and COS and the like for basic repeater operation. Haven't even gone down the P25 route yet, which requires a V.24 board, but that's for another day.
Thanks in advance for any clues you may be able to pass on.
BTW: This is actual a 'QuanTro' with the external 225Watt UHF PA, but that shouldn't be any relevance, that I know of, to the basic SCM to 8WL card compatibility issue. Why 8WL card you ask? Will that gives me the 'enhanced' option in the Wireline Configuration which I need for this AllStar connectivity.
73's
K6CV
73's
K6CV
