Quantar Simulcast error at all sites
syscon411
Hello,
So I have a strange error that just started appearing at all 3 of our Quantar simulcast sites when reconfiguring them for simulcast. "WL CTRL SIMULCAST 1PPS 188 SWARE INVALID LAUNCH TIME". Everything works and transmits when we turn off the simulcast, but obviously, the audio is totally garbage as we have transmitter overlap in areas
We have 3 sites each with a single quantar connected to a conventional atac 3k. everything is in astro/p25 mode. We don't do any analog. Everything is connected via v.24 to the atac via serial over IP. Our IP network is a dedicated MPLS fiber network. We have the 10mhz and 1pps all connected to GPS receivers.
This is not a public safety system. It's just for general business use that spans across 3 small cities. We decided that we wanted everything on a single channel and not have to change channels when we moved from one area to another.
Any help would be appreciated.
xmo
Did the system ever work in simulcast or are you now "reconfiguring them for simulcast." for the first time?
Did you 'stage' all the equipment first in one place to verify operation before installing in the field?
syscon411
Yep, the quantar at the comparator is in the same rack with a cross-over going directly between the two. 1PPS looks good on the o-scope. no errors on the comparator. I even re-tuned the Ref Oscillator on the comparator.
This is a re-config. Everything worked before we turned on the simulcast, matched all the TX freqs to the same, and re-tuned all the filters.
kf8yk
Is simulcast enabled in the comparator & is the simulcast launch time delay in the comparator set high enough to cover your worst case network delay?
In the Quantar codeplug under Service->Alignment->Astro Simulcast Test Pattern section is the desired launch time offset set to zero?
Are all the Quantars running identical firmware? There's issues with simulcast & mixing firmware versions.
syscon411
simulcast is enabled on the comparator launch time is set at 4ms higher than our highest average link delay. all stations are on R20.13.017. All station simulcast is set to zero. default transmit steering address is 3F, comparator is running ver R03.19.001. I got good HDLC link to everything and no errors on any of the v.24.
"It hates me now! LOL!"
xmo
Are you working from the GPS simulcast installation manual?
Here are a few pages that may prove helpful.
  • Sinulcast optimization.pdf
