DSDPlus Question on enc display on event log
bravo14
Polk County FL
I’m running the latest update 395. I notice the other day on event log it doesn’t show the keyid and what type it is. Yesterday I was helping someone set up their dsdplus and it was showing up on their computer. I’m on win10. Today I decide to start from scratch and still isn’t popping up in event log is there a setting or some kind of glitch?
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
I believe you have to enable voice following and have either partial or full following enabled under encrypted voice call following.
bravo14
Polk County FL
Seems the 395 isn’t working. I went to the 384 and showing clear on the tg side and 395 doesn’t show that.
cg
Connecticut
Been working fine here since the version came out. As mentioned, you need to be following the talkgroup as the enc info is on the voice channel. Be sure your priority is set to allow the talkgroup to be followed and that you are allowing encrypted voice following on the Control tab.
