Question on NAS
fmcc0789
Im usually not that guy but you have a lot more research to do. The answers are out there but stick with a scanner until you know how trunking operates while in use with a two way radio. If you want PM me and I'll see if I can find some time this weekend to help you.
Im fine because I dont have 600$ to spend on a SDS-100 as my system is simulcast and P25 phase 2.
K2NEC
5F6
Then what radio are you trying to program for NAS because anything that you can NAS Phase II on is more than $600
Well he has an XTS5000 that he has tried in other threads to get working. Tried to monitor Phase 2 with an XPR6550...
The system OP points out does have quite a few Phase I talkgroups, so maybe one of those?
rbrtklamp2
Dupage County, Illinois
Wow that kinda takes the cake there! This guy needs to buy a dongle and start researching two waubradios amd how they operate. To the OP I would start with monitoring conventional channels because you can really cause issues if you don't know how to operate trunking systems.
KD8RFT
Grosse Ile Township, Michigan
Take a look at SDR (Software Defined Radio). You can set up a cheap dongle or two on your computer, coupled with SDRTrunk or DSD Plus Fastlane and you can decode and see all traffic going through the P25 system you want to monitor in real time. This will also teach you how the P25 systems work. Much less expensive than any P25 radio or scanner.
AM909
Radio/computer geek
SoCal
Another vote for SDR, as long as you're somewhat computer-savvy. Suggest RTL2832-based SDR (NESDR or rtl-sdr.com), SDRSharp, DSD+ Fastlane, SDRTrunk, Unitrunker. You'll want one SDR for control channel and one for every 1.9 MHz you need to cover simultaneously. That's a total of either 3 or 4 SDR for the freqs shown above, depending on whether the upper channels marked as control-capable actually get used for traffic otherwise.
