Question on very low volume
crowbar46okla
My General Lee has very low volume and very low modulation, the transmit signal is very good and the receiving signal is very good, what could cause this?
WSAC829
Mike Oscar 225
EN64ak
Agree. I would check the solder connections on the audio IC. Sometimes a few pins end up with bad solder joints over time. A simple reflow of those joints might bring it back to life.
crowbar46okla
Thank you for the info, I resoldered some joints but it didn't help, I installed a TDA 2003 Amp ic and it took right off thank you for the help.
