- Joined
- Oct 27, 2002
- Messages
- 2,382
- Reaction score
- 1,402
Hello,
I am in the process of experimenting with a new type of scanner feed. This feed uses a Uniden BC780XLT (or 796, which I'm testing with). Information is extracted from the 780 via a terminal program. Another program views the information received from the 780 by the terminal program, and checks it against a text file with alpha tags. The alpha tag is then sent to a program called Simplecast, which provides the audio stream to Icecast, an audio feed server. Clients can connect to the feed via Winamp (or equivalent), listen to the feed, and can see the alpha tag in the section of Winamp that normally displays song or file information.
I am able to extract talkgroup ID data without a problem using the IDN command. This works superbly. However, I am having no success at all trying to have conventional frequency data stream from the 780. I have checked, re-checked, and re-re-checked Uniden software protocol websites, including the superb one located at The Freq of Nature site, http://www.freqofnature.com/software/protocols.html . I have tried what I thought to be the correct commands. However, it appears that only two commands, the aforementioned IDN and the CDN command (provides subaudible tone info) provide streaming data from the 780 (or 796).
Can anyone here with programming experience shed some light on how I might successfully accomplish this? It HAS to be possible, otherwise programs like ARC780, ARC250, Scan*Star, wouldn't work with displaying conventional data.
I have made this inquiry elsewhere as well, and have received some replies, none of which I've been successful with to date. I have an inquiry in to Gommert Buysen of Butel Software but he's on holiday until 9/20. If anyone has any information I would be indebted. This is a really neat way of providing alpha tag data for a scanner feed, but I'm coming up short in this vital area. To cover my area properly I have to scan both trunked and conventional systems.
If you run Winamp and would like to see an example of what this feed looks like, check the following site:
http://sagansstash.ucsd.edu/Scanner/connect.html
Click on the yellow "Tune In" button at the top of the page.
Thanks in advance.
Thanks in advance.
