Yaesu: Question Regarding Yaesu FT-8900R
radiobuff0978
Indianapolis, IN
I want to use the FT8900R to participate in a net on 6 Meters. They Receive on 52.700 and Transmit on 51.700. Looking at the manual, ARS is enabled and the manual indicates that the offset or shift is 1 M down.
I tune it to 52.700 and when I key the mic it does not change the frequency to 51.700. I have done a split on my HF rig (ICOM 7200), so I assume that the tx frequency will display when transmitting. What am I missing?
Is there some additional documentation, or videos, etc that illustrates how to set this up on the FT 8900R?
Thanks in advance for any help
kb6nzv
Salem, OR
With the correct radio programming utility (FTB8900 or CHIRP) it would be simple to load a non-standard input offset. I believe that unless you specify an offset the 8900 will assume simplex which seems to match your observation about how the radio behaved.
G4HFQ Software - FTB8900 Details
Download - CHIRP
Improved FT-8900r programming guide by W5JCK:
http://www.w5jck.com/downloads/Yaesu_FT-8900R_manual_w5jck_expanded_version.pdf
73, Phil KB6NZV
