QYT KT8900D volume
Kirk1959
I put a KT8900D in my Jeep because I would not be out much if it got stolen. It has worked well but recently, the radio has no volume. Being a new Tech operator, I think I might’ve pushed the wrong button somewhere. Nothing in the manual helped me. Any ideas ?
K4EET
Chaplain
Severn, Maryland, USA
Kirk1959, firstly, welcome to Radio Reference (RR)!
Let me ask... How old is your QYT KT8900D and has it seen a lot of rough duty like off-roading with it? I'm just trying to decide if it could be a failure rather than a wrong button push...
Thanks es 73, Dave K4EET
Kirk1959
No sir, not much off reading. Radio is six months old. I keep the windows down to avoid excessive heat. More likely something I fat fingered. Grateful for any help.
K4EET
Chaplain
Kirk1959, thanks for the information. I used to have a 2004 Jeep Rubicon (TJ) and did a lot of rock crawling which is why I asked. If you think it is just a cockpit error, i.e., fat fingers, I downloaded the manual to have a look at the controls on the front panel and to get a little familiar with the rig. Let me ask some more questions, when you say "the radio has no volume" does that mean the radio is totally silent? Not a peep out of it at all? No beep when you turn it on, no beep on button pushes, no receive audio on any repeater when active, etc.? Does the signal strength indicator increase to the right when a repeater becomes active? If you transmit on a repeater, does your transmitted audio go out (you'll need a working receiver for that test)? By the way, are you an Amateur Radio operator? Please answer each one of those questions. Thanks!
73, Dave K4EET
