10.7 MHz IF Output Report
Hello,
I had the 10.7 MHz IF mod completed by a tech at the Woods Hole Oceanographic Institute (read: someone that excels at such things) and just got it back today. I have had the opportunity to interface it with a spectrum analyzer. The output is indeed VERY strong, to the point that I had to attenuate it 10 db, which made a distinct display improvement. The output also seems to be quite clean. I've looked at VHF-HI, UHF, UHF-T, 800, and 900 MHz bands with it. I saw one spur on VHF-HI, and have yet to see any elsewhere. As was stated before the IF output works in all modes. I copied the text and photos from the mod that Lindsay completed (thanks to W1PC for his input also) and the exact same steps were taken.
With the above in mind it seems apparent that this will work just fine for spectrum analyzers and/or spectrum display units that will take a 10.7 MHz IF input.
I have compared my R2500 with an Icom IC-R7000's 10.7 IF out as well. The output of the 2500 is definitely stronger than that of the R7000. Weaker signals seem to be more evident with the R2500 than they are with the R7000.
Hopefully this will encourage folks that wish to use these radios for spectrum analysis. Thanks to all that participated!
