pittsville
- Joined
- Jan 5, 2008
- Messages
- 11
I have an Icom R8500 that I bought used. It worked fine for several years, but now it loses all of it's frequencies that are entered into memory whenever I turn it off.
Also the radio was unblocked when I bought it. I don't know if is an early model that was restored, or if it came unblocked from the factory. In relation to this, when the radio loses it's frequencies it also becomes a blocked model! I can restore full coverage by performing the reset, but it goes back to being blocked when it loses it's memory.
I don't think this model has an internal battery for memory backup. From what I've read it's supposed to be non-volatile, which I think means it doesn't have a battery. I'm into the top of the radio and I don't see one. I might pull the bottom cover off and look in there to see if it has one.
I took the top off to see if I could spot any leaking or bulged capacitors but I don't see any. I noticed it looks like there's been some heat coming from the cluster of capacitors that are near where the power supply plugs into the radio. I suppose one of them might be bad. The radio also sort of pops (from the speaker) when I power it on. I can't remember if it always did that or not, but I think I remember reading that the pop could mean a bad capacitor.
I have a couple of other radios that need to be sent to Icom for repair so I'll probably add this one to the list, but I was wondering if anyone else ever experienced this problem, and what it might be?
