Radial Length NMO Base Kit
davee223
New Jersey
Does anyone know the proper formula for the length of the ground plane radials for a 5/8 wave 450-470 mobile antenna. I purchased the kit and only have the formula for a 1/4 wave antenna. The antenna is only being used for receiving.
N5XPM
Texas
For receiving only, you will not notice a difference and should be fine regardless of radial length.
RadShackFan
Auburn, Alabama
Scroll down and you will find the formula calculator.
n0nhp
Grand Junction
As long as the ground plane is 1/4 wave length or longer, it doesn't matter, transmit or receive
Yeah, for the ground plane, Minimum of 1/4 wave is all you need. In other words, you do not need to have 5/8 wave ground radials for a 5/8 wave antenna.
N5XPM
Texas
For commercially available "kits" they offer the kit by frequency band. The VHF kit will work for UHF, as the 1/4 wave VHF kit is longer than the 1/4 wave required for UHF frequencies. Since there are several radials, you are effectively creating a 1/2 wave ground plane. For transmitting, the UHF kit won't work well for VHF, since the radials are about 6" versus the 18" needed for the VHF frequency bands. For a base scanner antenna, the VHF base kit with a Tri-band mobile NMO mobile antenna is affordable and durable.
